Problem: I would like to change Reset address (0x0000) to another one (0x800000) in the MONITOR Mode, because in our hardware RAM starts at this address. I am able to load my program into RAM using bootstrap mode and my MONITOR, but I am unable to run or debug my proram. Thanks for help Aram
In uVision2: 1. In Project Options-Target Options: un-check the Use on-chip RAM and Use on-chip ROM check boxes. 2. In Project Options-Target Options: under External Memory enter the appropriate ROM range and RAM range. ROM will probably be starting at 0x80000 (for a length of 0x8000) and RAM will probably start at 0x88000 (for a length of 0x8000). 3. In Project Options-L166 Misc: enter 0x80000 for the Interrupt Vector Table Address. 4. Be sure to include the START167.A66 startup file in your project. Rebuild your project and take a look at the MAP file. You should see everything in the correct place. I tried this with the HELLO example program. Following is the MAP file output from that build.
MEMORY MAP OF MODULE: Hello (HELLO) START STOP LENGTH TYPE RTYP ALIGN TGR GRP COMB CLASS SECTION NAME ===================================================================================== 00FA00H 00FBFFH 000200H --- --- --- --- --- --- * SYSTEM STACK * 00FC00H 00FC1FH 000020H DATA --- BYTE --- --- --- *REG* ?C_MAINREGISTERS 080000H 080003H 000004H --- --- --- --- --- --- * INTVECTOR TABLE * 080004H 080005H 000002H XDATA REL WORD --- --- GLOB --- ?C_INITSEC 080006H 080045H 000040H DATA REL WORD --- 2 PUBL NCONST ?NC??PRNFMT 080046H 080052H 00000DH DATA REL BYTE --- 2 PUBL NCONST ?NC?HELLO 080054H 080171H 00011EH CODE REL WORD --- --- PRIV ICODE ?C_STARTUP_CODE 080172H 080475H 000304H CODE REL WORD --- 1 PUBL NCODE ?C_LIB_CODE 080476H 0804A7H 000032H CODE REL WORD --- 1 PRIV NCODE ?PR?PUTCHAR 0804A8H 0804CDH 000026H CODE REL WORD --- 1 PUBL NCODE ?PR?HELLO 088000H 0881FFH 000200H DATA REL WORD --- 3 PUBL NDATA ?C_USERSTACK
