Hello all,
I am working on a navigation project that requires reading IMU heading data as an output. I have chosen the STM32F401VCTx chip for my custom board and am interfacing with an Adafruit IMU. Communication is through I2C, which I have some experience with but not a ton. The slave address for the BNO055 on the IMU is 0x28, which when bit shifted is 0x50. I am using the HAL functions provided by uVision for I2C transactions, namely the Mem_Read and Mem_Write functions for peripherals. I have configured the device to operate in "compass mode" and output a heading angle in radians, and store it in the bytes EUL_Heading_MSB and EUL_Heading_LSB. I want to see the heading bytes.
Code:
uint8_t COMPASS_MODE = 0x09; //Compass mode value 1001 uint8_t UNIT_SEL = 0x04; //Radians value 0100 uint8_t EUL_Heading_MSB[1] = {0x00}; //initialize MSB of output data uint8_t EUL_Heading_LSB[1] = {0x00}; //initialize LSB of output data HAL_I2C_Mem_Write(&hi2c1, 0x50, 0x3D, 1, &COMPASS_MODE , 1, 50); //Setting OPR_MODE register to 1001 to initialize compass mode HAL_I2C_Mem_Write(&hi2c1, 0x50, 0x3B, 1, &UNIT_SEL, 1, 50); //Setting UNIT_SEL to 0100 for radians HAL_I2C_Mem_Read(&hi2c1, 0x50, 0x1B, 1, EUL_Heading_MSB, 1, 50); //Read EUL_Heading_MSB data from 0x1B register HAL_I2C_Mem_Read(&hi2c1, 0x50, 0x1A, 1, EUL_Heading_LSB, 1, 50); //Read EUL_Heading_LSB data from 0x1A register
I am not seeing a readable output in uVision. I know to use Watch windows to view output, but I am not sure if it is working correctly. Here is a pic of my watch window:
If anyone has worked on a similar project, or knows of a possible solution/alternative please help out if possible.
Thanks in advance :)
