I am looking for some help with my Keil uVision 5.27. I am able to run some example code for my chip that I downloaded from NXP. I have 0 errors and 0 warnings. I am able to go into the debug mode, but when I set a breakpoint in the main code, it won't run to the breakpoint. It seems like it is stuck in an infinite loop somewhere and not running to main. I don't know where it is stuck at either. When I step line-by-line through the code, it looks like it is going through Disassembly code at the top of my screen. I think it might have to do with the starting of the chip maybe a startup file or something.
I think this is why all the pins on my chip are at 3.3V. It might not be flash downloading properly. I am however able to change the output of the pins when I am in debug mode and I can set the peripheral GPIOs to 0. When I reset however, the pins go back to 3.3V.
How do I fix this so I am not constantly in Disassembly? I need to be able to debug the code and I can't.
If anyone can help me that would be greatly appreciated.
Thank you
