The documentation has removed support for Arm IPMI Energy Agent since Arm forge 21.1, and the Arm IPMI Energy Agent file is also missing from the download page. Documentation says that the old system Cray HSS energy counters are required for Node power monitoring, but it will be replaced by the Node power Will you no longer support Node power monitoring?
Hi Masashi,
Forge still continues to support Node power monitoring through the Cray HSS energy counters and RAPL (for systems that still use these).
