severity: urgent, may impact if we could use these ARM sram in Project for UMC22ULPULL tapeout
1. DRC failed on rule “ EXTRA_JOG_RULE_PMETGMK”
2. DRC deck version: G-DF-LOGIC_MIXED_MODE22N-ULP_ULL-1P7M0T0A0C1U-CALIBRE-DRC-1.7_P1
3. sram compiler : rf_sp_hde_svt_mvt , rf_2p_hdc_svt_mvt
Hi Eden.Cai
This is definitely the wrong forum to ask this question and I'm afraid I can't help you with it.
I would try contacting support@arm.com and supply which Arm tools are you using and instructions to reproduce the problem.
Ta
Rich
Thank you, I also submit a support case to the web site https://developer.arm.com/support,
03386374 – UMC22ULPULL SRAM compiler rf_sp_hde_svt_mvt , rf_2p_hdc_svt_mvt DRC failed issue – opened
ARM tool for UM31 UMC22ULPULL SRAM compiler as listed below
High Density single Port register File SVT MVT Compiler Release Notes (UM31CD001)
High Density Two Port register File SVT MVT Compiler Release Notes (UM31CE000)
