While using map's GUI, I am getting the error message
Process 0:
The target's CPU ID (0x00000000430f0af0) doesn't match the requested CPU ID (0x00000000460f0010)
This doesn't happen with "map -profile ..." and nobody else seems to be able to replicate.
System is a ThunderX2 node (/proc/cpuinfo matches the target CPU ID), compiling with gcc 8 (from CentOS), armclang, and others.
Self-solved: turned out I had a ~/.allinea directory with a system.config setting for the wrong CPU ID. This was presumably set by an earlier version of forge. Wiped directory and now runs ok.
NEED MORE SOLUTION FOR THIS PROBLRM ALREADY APPLIED THIS ONE
Hello
Could you provide more information on the problem you are seeing if the above solution is not working for you? Also, preferably not in all caps :)
