pixmap example for opengl es 2.0 on linux(x11 backend)
Hi Community,
Is there any simple sample example available in order to create Pixmap surface ?
I am using Mali400 & LInux as OS. My backend/Windowing System is X11. I tried to look into ARM SDK/emulator but coudnt find any example C code.
Thanks,
VK
  • Hi Vaibhav,
    You can create a Pixmap surface in X11 using the XCreatePixmap function.
     pixmap = XCreatePixmap(display, window, width, height, depth);
    The function returns a Pixmap object that can be passed into eglCreateImage as EGLClientBuffer parameter to associate an eglImage to the Pixmap.
    eglCreateImageKHR(eglDisplay, EGL_NO_CONTEXT, EGL_NATIVE_PIXMAP_KHR, reinterpret_cast<EGLClientBuffer> pixmap , imageAttributes));
    You can then connect the EGLImage to a GLES Texture using glEGLImageTargetTexture2DOES and render to the texture using the GPU as an example.
    Regards,
    Daniele
