Not able to connect to MGD to target running Linux
I am using Linux on the target machine and I am not able to connect to the mgddaemon from Windows system.
Setup Done on arm64 target:
1. copied interceptor lib on the target device in /usr/lib64/
2. copied mgddaemon on target device in /usr/bin/
3. execute permission added to mgddaemon.
I can see mgddaemon running on the target but when I am trying to connect GUI to daemon I am getting following error.
"Connection refused: connect
Cannot connect to 127.0.0.1:5002
Either the network connection to your target device is not working or mgddaemon is not running on the target."
I recently moved from Android to linux and on Android I used to do adb forward tcp:5002 tcp:5002 before we connect from GUI.
Do I need to do something similar from the linux system to get the connection to target?
Cheers
-Virender
