Query on $MaliCoreInstructionsNarrowInstructions
Hi Forum,
As per perf counter guide, counter $MaliCoreInstructionsNarrowInstructions increments for every 8-bit or 16-bit instruction execution. To understand counter further, when tried with simple medium precision test observed part of 16-bit instructions are reported in $MaliALUInstructionsFMAInstructions as well. is it expected?
the following test executed on G720 and collected data using streamline version 8.9.0
precision mediump float;
in vec4 in1, in2;
out vec4 col;
main( ) { col = in1 * in2; }
Mali ALU Instructions:FMA instructions Mali ALU Instructions:Narrow instructions Mali Shader Warps:Fragment warps
8335 8325 16454
the total ALUs are 4. Narrow should be included to get 4, formula: ((FMA+Narrow)*4)/Warps
when tried the same test in high precision, data is as expected
16544 0 16454
Thanks,
Venkatesh.
