Pixels metric in Performance Advisor
Hi, I've been investigating our game performance recently with PA and have some issues in understanding metrics.
There's a metric called "Pixels per frame", which has the following description:
"An increase in the number of pixels that are rendered per frame usually indicates changes in the application render pass configuration. For example, adding more passes for new shadow casters or post-processing effects may cause the render pass to perform inefficiently."
Also I've found some info in precise GPU docs (Mali G-76 MP12) here https://developer.arm.com/documentation/102697/0107/Content-behavior?lang=en which says:
"This expression defines the total number of pixels that are shaded by the GPU, including on-screen and off-screen render passes.
This measure can be a slight overestimate because it assumes all pixels in each active 32x32 pixel region are shaded. If the rendered region does not align with 32 pixel aligned boundaries, then this metric includes pixels that are not actually shaded.
$MaliGPUTasksFragmentTasks * 1024"
As I've seen from the reports, for our game and this gpu it oscillates around 8-10M, so it's smth like 9M on average (for rendering resolution set to 1140 x 540). Also I've tried increasing rendering rendering resolution to 2280 x 1080 and it did not impact the values at all (neither enabling MSAA did), so for me it seems to be some kind of "operations per pixel" metric, which is dependent on $MaliGPUTasksFragmentTasks value.
Could you please provide some insights about what exactly this metric is about and why does it not scale with framebuffer size?
