I am using std140 for Uniform Block Layout, I defined a simple uniform block like below:
on the cpu side, I defined the structure like MyTestStruct {Vector4 FinalColor1;
Vector4 FinalColor2;
Vector4 ColorIndex;
Vector4 FinalColor3;
I tested mediump data precision in the shader and It works on my android phone with MaliG76. but I don't known if this is valid on all mali gpu.
layout(binding = 0, std140) uniform MyTestBlock {mediump vec4 FinalColor1;mediump vec4 FinalColor2;mediump vec4 ColorIndex;mediump vec4 FinalColor3;};
Will there be a default highp->mediump conversion? If Yes, is it on every shader execution or is there a special optimization?
Thanks!
