what can we benefit from single channel texture for performance
I know that single channel texture,like a R8 texture, is smaller compared with ordinary RGB24 or RGBA32 texture with the same resolution,say both are 256x256 pixals. My question is whether it also helps to increase texture cache hit rate for using single channel if possiable. And does the single channel texture compression format well supported in mobile GPU above opengl es 3.0. And besides these, what else can we benefit if using single channel texture.It will be really appreciate if any one can help. Thx.
0
