Site
Search
User
Site
Search
User
Support forums
FBO doesn't work?
Locked
Locked
Replies
Subscribers
137 subscribers
Views
Users
0 members are here
Mali-GPU
Mali-400
Options
More actions
Related
How was your experience today?
FBO doesn't work?
Christopher Van Kirk
over 12 years ago
Note: This was originally posted on 12th September 2011 at
http://forums.arm.com
Sorry, this is a repost of a question I added to someone else's thread. It's a similar issue, but went unanswered. I kind of need to get an answer on this:
I create the FBO, bind it to a texture, check the status to make sure it's framebuffer complete, then set it to the rendering buffer, and call DrawElements. DrawElements fails with "GL_INVALID_FRAMEBUFFER_OPERATION" error. This is a bit of a mystery since I check the completeness status on the line immediately prior to the draw call and it claims to be framebuffer complete.
Do the settings on the texture object matter, e.g. repeat/linear/reflect. Does Mali require me to specify a depth or stencil buffer? Does it require an alpha channel?
This code works on Tegra2 and Adreno 205. Not sure why Mali doesn't like it.
Cheers!
Edit: Added example Android code that doesn't work as it should on the SGS2.
0
Quote
