Site
Search
User
Site
Search
User
Support forums
Debugging Mali driver in 3.4 kernel in Origen
Locked
Locked
Replies
Subscribers
137 subscribers
Views
Users
0 members are here
Android
Memory Management Unit
Mali Drivers
Mali-GPU
Options
More actions
Related
How was your experience today?
Sangwook Lee
over 12 years ago
Note: This was originally posted on 26th April 2012 at
http://forums.arm.com
Hello
I am trying to make ICS Android (Mali) work in Origen with 3.4 kernel
Now as using Mali driver, gralloc_ump r2p4-02rel in 3.4 kernel with the following Android branch.
repo init -u git://
android.git.linaro.org/platform/manifest.git
-b linaro_android_4.0.4 -m tracking-origen.xml
I have the following errors:
[ 15.225000] MALI PHYSICAL RANGE VALIDATION ERROR!
[ 15.235000] We failed to validate a Mali-Physical range that the user-side wished to map in
[ 15.245000] It is likely that the user-side wished to do Direct Rendering, but a suitable
[ 15.250000] address range validation mechanism has not been correctly setup
[ 15.260000] The range supplied was: phys_base=0x6D900000, size=0x004B0000
[ 15.270000] Please refer to the ARM Mali Software Integration Guide for more information.
[ 15.275000] *******************************************************************************
In my opinion, it seems that user space library call ioctl command with in-proper argument.
ioctl command (MALI_IOC_MEM_MAP_EXT) with the wrong params: phys_base=0x6D900000, size=0x004B0000
In addition, currently I didn't add UMP remap call in Framebuffer drivers. Is it possible reason ?
Sangwook
0
Quote
