I'm working on an algorithm where I need to detect if the current `gl_FragCoord` is an even or odd row/column. A typical implementation would look something like `if (mod(gl_FragCoord.x, 2.0) < 1.0) { ... } else { ... }`. After running into issues with this approach a quick google search pointed me to quite some good information:
Especially this forum post is pretty much identical to the issue I'm looking into.
I've created this repository to experiment with this issue and to solve it. I'm using a MiBox MDZ-16-AB. This repository is created for Android Studio. It will setup a basic custom `GLSurfaceView` that uses the `TestGlView` that instantiates the `TestGlRenderer` class. In `TestGlRenderer` I create a simple filter shader that applies the `if (mod(..))` logic to draw different colors for odd/even columns. I create a FBO with a size of 3840 x 2160 to detect floating point precision issues. When rendering into a FBO with a color attachment of a texture with a size of 1920 x 1080 the issues is a lot less.
In the image below (3840 x 2160) you can clearly see the issue. It should show vertical red and black lines from left to right.
When rendering using a 1920 x 1080 things get a little bit better, but still not 100% correct.
In `TestGlRenderer` I create an instance of `GlRenderToTexture` which is just a thin wrapper that create a FBO with one texture attachment. In `onSurfaceCreated()` of the `TestGlRenderer` class I create an instance of `GlRenderToTexture`. In the code I've added (a commented) version which creates either a 1920x1080 or 3840x2160 FBO.
Now I'm curious what would be a workaround or solution to be able to distinguish between odd and even rows/columns?
The Mali-400 series programmable core only supports FP16 precision in the arithmetic units, so anything using arithmetic to do this won't have enough precision.
There is a higher precision path between the varying unit and the texturing unit. I'd recommend creating a texture-based lookup table which is the width of the framebuffer and 1 pixel high which alternates black and white pixels. Use a varying lookup to index into the texture using GL_NEAREST filtering, and then use the returned color to determine odd or even.
Obviously this gets harder with non-fullscreen geometry, or geometry which moves, but I don't think we have a general purpose solution to this on the Mali-400 series once framebuffers get above a certain size.
Hope that helps, Pete
Thanks for your reply and great suggestion. This was one of the two possible solutions I was thinking about; the other solution I was thinking about was creating some sort of tiled based rendering where I render / execute the fragment shader only on portions of the framebuffer; but I did not research if this is a sound solution yet. Using a texture lookup with 1 pixel height seems to be the best alternative.
If you go for tiled framebuffers, for FP16 you get 10 bits of mantissa so you should only be able to accurately address 2^10 = 1024 pixel wide framebuffers using gl_FragCoord.
I'm experimenting with this using the public test repository I created but the results I get are the same. At L23 I set the `highp` precision. and at L42 I fetch the pixels from the lookup table. The width of the lookup table is the same as the viewport/fbo into which I render (3840x2160).
This is the result when I render into 1920 x 1080, which looks correct:
But when I render into a 3840 x 2160 and then render that to the default framebuffer, I get something similar to the above issue:
It still seems like a precision issue; but if the texture lookups are done using a highp variant.
I assume you are downsampling from 2160p (offscreen) to 1080p (onscreen), so the downsample isn't going to be stable with GL_NEAREST filtering (you have twice as many texels as you have pixels, so the choice of black or white is going to be a bit unstable).
To verify that the 2160p render is doing the right thing I'd suggest a glReadPixels call just to snapshot the memory - it removes one moving part from the sequence.
Ah offcourse. Totally makes sense. The reason I was using GL_NEAREST was that GL_LINEAR would give me a grayish output. But you are totally right, I should use glReadPixels to download the result. Thanks and sorry for this silly mistake.
Great, I can confirm that using a lookup texture works.
I've got another related question: let's say that I have a fragment shader that I use when rendering into a texture 3840x2160 with an FBO. In this shader, I also want to sample from another texture of a size 1920x1080. But, I want to fetch the pixels around the current fragcoord taking into account the scaling.
So let's say that gl_FragCoord is 1920x1080 (so half of the FBO attachment texture), this means that my texture coordinate that has a value of (0.5, 0.5). When I want to sample the corresponding pixel from my smaller texture (the one of 1920x1080) I can simply use that texture coordinate. Using this would fetch me the pixel at (1920 * 0.5, 1080 * 0.5) => (960 x 540). But what if I want to fetch one pixel to the left and one pixel to the right of this one. So (959 x 540) and (961 x 540). I'm asking because I suspect that using arithmic in the fragment shader won't allow me to do this because of the low precision. Am I right?
If you try to do this with arithmetic in the shader code, then you are correct. As soon as you do any arithmetic on a variable you'll drop to fp16 precision. As a workaround you could simply create multiple texture coordinate varyings, each offset by one pixel's worth of space, and pass each directly into a texture call.
For a complex mesh that's going to be expensive in terms of varying memory bandwidth, but for a simple full screen quad I wouldn't expect that to be a major problem in terms of performance.
Thanks for the suggestion. Would that mean that in this case I would need 3 varyings? One for sampling the center pixel, one for the left and one for the right? And do you mean that I would have to upload these varyings as vertex attributes? I'm wondering how the varyings for the left and right lookup could be constructed as a varying.
Yes, that's the idea.
For normal texel centers your varyings are set to range from 0 to 1 across the triangle, which gives you samples at texel centers. If you know your texture is 1024 wide then you simply need to adjust the varyings to be offset by 1/1024 (subtract that to shift a sample left, and add it to shift a sample right).
