to size boundary of the structure alignment
dear All,
i started an arm cortex m3 project using eclipse+gnu.
i want to size boundary of the structure alignment.
where and how i can do it?
thanks and regards,
Ras
  • Hi Ras,
    it would be possible if the structure size is a positive power of 2.
    For example, the code
    struct struct1 {
     int i[10];// 40 bytes
     char c[24];// 24 bytes
    struct struct1 __attribute__ ((aligned(sizeof(struct struct1)))) ic;
    int main()
     ic.i[0]=0x12345678;
     ic.c[1]=0x5a;
     return 0;
    would be compiled as the followings.
              .text
            .align  2
            .global main
            .thumb
            .thumb_func
            .type   main, %function
    main:
            ldr     r3, .L2
            ldr     r2, .L2+4
            str     r2, [r3]
            movs    r2, #90
            strb    r2, [r3, #41]
            movs    r0, #0
            bx      lr
    .L3:
            .align  2
    .L2:
            .word   ic
            .word   305419896
            .size   main, .-main
            .comm   ic,64,64
    Is this your intention?
    Best regards,
    Yasuhiko Koumoto.
