I am interested in using Thread networking from mbed OS. Is there an example or starter anywhere which I can try? Can I connect to an Mbed device connector using a Thread network and with an mbed client?
Additionally, ARM is mentioned in the Openthread implementation and I would be interested to know if there are any ARM mbed compiled examples available using this.
Hi rapport and welcome to the Community!
I have moved your question to Internet of Things where I hope someone can help, if not there is also a specialised board for mbed.
I suggest you this one :
More Hardware! STMicroelectronics launches mbed-enabled family with NUCLEO | mbed
I used mbed.org environement with one of this board at the first time, and they are clearly compatible
with a lowest cost.
Good luck
Thanks commenting and for sending a link which looks interesting entry point for programming in mbed. However, I am having trouble figuring out how I can get it working with a Thread network.
Say for example I want to attach accelerometer to make it work as a fall sensor - how can I do the radio coms and send a Alarm on a Thread network in a connected home... Is there radio driver available in MBed for Thread on this board? Or would I need to plugin a USB Thread shield or usb such as EM358 USB stick to get it working? Are there examples?
