ARM Cortex-M4 (Nuvoton NUC472) not booting with External RAM on EBI Interface
We are working on ARM Cortex-M4 (Nuvoton NUC472) based SoC as per our requirement.We are facing one critical issue like board is not booting when we enabled and used extrenal RAM on EBI.
We have ported following BSP package with below toolchain for NUC472.
We have created bare framework with above BSP and we are able to start the board with existing ld script provided in BSP with internal RAM support.
Now, We have added the support for external RAM of 512KB on EBI in linker script as per our requirement to move few libraries into external RAM.So, We have added one test library and placed in external ram to validate and test external RAM with our bare build.
But, Board does not starts if we make any variable as extern to use from library which is placed into external RAM.
It is working fine If we are putting that library into internal RAM then board gets up and running without any stuck up issue.
Please find following CFLAGS and LDFLAGS options which we are using into our compilation support.
CFLAGS :
        -mcpu=cortex-m4
        -mthumb
        -mfpu=fpv4-sp-d16
        -mfloat-abi=hard
        -g2
        -Wall
        -c
        -DNUC442RI8AE
        -D__FPU_USED -std=c99
        -ffunction-sections -fdata-sections
        -fstrict-volatile-bitfields
        -fno-short-enums
LDFLAGS :
        -Wl,--gc-sections
        -Wl,-static
        -Xlinker --no-enum-size-warning
        -Xlinker --wrap=_malloc_r
        -Xlinker --wrap=_free_r
        -Xlinker --wrap=_calloc_r
        -Xlinker --wrap=_realloc_r
        -Wl,--start-group
        -lgcc -lc -lm -lnosys
        -Wl,--end-group
Please find following list of libraries which we have moved into external RAM
  1. test library
  2. FreeRTOS Heap Memory
Please find attached sample multi RAM linker script (for reference) and our own sample linker script which we have used into our example
  • Sample multi RAM linker script (for reference)
/* Linker script to configure memory regions.
 * Need modifying for a specific board.
 *   FLASH.ORIGIN: starting address of flash
 *   FLASH.LENGTH: length of flash
 *   RAM.ORIGIN: starting address of RAM bank 0
 *   RAM.LENGTH: length of RAM bank 0
MEMORY
  FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x20000 /* 128K */
  RAM (rwx) : ORIGIN = 0x10000000, LENGTH = 0x2000 /* 8K */
  RAM2 (rwx) : ORIGIN = 0x20000000, LENGTH = 0x2000 /* 8K */
/* Linker script to place sections and symbol values. Should be used together
 * with other linker script that defines memory regions FLASH and RAM.
 * It references following symbols, which must be defined in code:
 *   Reset_Handler : Entry of reset handler
 * It defines following symbols, which code can use without definition:
 *   __exidx_start
 *   __exidx_end
 *   __copy_table_start__
 *   __copy_table_end__
 *   __zero_table_start__
 *   __zero_table_end__
 *   __etext
 *   __data_start__
 *   __preinit_array_start
 *   __preinit_array_end
 *   __init_array_start
 *   __init_array_end
 *   __fini_array_start
 *   __fini_array_end
 *   __data_end__
 *   __bss_start__
 *   __bss_end__
 *   __end__
 *   end
 *   __HeapLimit
 *   __StackLimit
 *   __StackTop
 *   __stack
ENTRY(Reset_Handler)
SECTIONS
	.text :
		KEEP(*(.isr_vector))
		*(.text*)
		KEEP(*(.init))
		KEEP(*(.fini))
		/* .ctors */
		*crtbegin.o(.ctors)
		*crtbegin?.o(.ctors)
		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
		*(SORT(.ctors.*))
		*(.ctors)
		/* .dtors */
 		*crtbegin.o(.dtors)
 		*crtbegin?.o(.dtors)
 		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
 		*(SORT(.dtors.*))
 		*(.dtors)
		*(.rodata*)
		KEEP(*(.eh_frame*))
	} > FLASH
	.ARM.extab :
		*(.ARM.extab* .gnu.linkonce.armextab.*)
	} > FLASH
	__exidx_start = .;
	.ARM.exidx :
		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
	} > FLASH
	__exidx_end = .;
	/* To copy multiple ROM to RAM sections,
	 * uncomment .copy.table section and,
	 * define __STARTUP_COPY_MULTIPLE in startup_ARMCMx.S */
	.copy.table :
		. = ALIGN(4);
		__copy_table_start__ = .;
		LONG (__etext)
		LONG (__data_start__)
		LONG (__data_end__ - __data_start__)
		LONG (__etext2)
		LONG (__data2_start__)
		LONG (__data2_end__ - __data2_start__)
		__copy_table_end__ = .;
	} > FLASH
	/* To clear multiple BSS sections,
	 * uncomment .zero.table section and,
	 * define __STARTUP_CLEAR_BSS_MULTIPLE in startup_ARMCMx.S */
	.zero.table :
		. = ALIGN(4);
		__zero_table_start__ = .;
		LONG (__bss_start__)
		LONG (__bss_end__ - __bss_start__)
		LONG (__bss2_start__)
		LONG (__bss2_end__ - __bss2_start__)
		__zero_table_end__ = .;
	} > FLASH
	/* Location counter can end up 2byte aligned with narrow Thumb code but
	   __etext is assumed by startup code to be the LMA of a section in RAM
	   which must be 4byte aligned */
	__etext = ALIGN (4);
	.data : AT (__etext)
		__data_start__ = .;
		*(vtable)
		*(.data*)
		__data_end__ = .;
	} > RAM
	   __etext2 is assumed by startup code to be the LMA of a section in
	   RAM which must be 4byte aligned */
	__etext2 = __etext + ALIGN (SIZEOF(.data), 4);
	.data2 : AT (__etext2)
		__data2_start__ = .;
		. = ALIGN(4);
		/* preinit data */
		PROVIDE_HIDDEN (__preinit_array_start = .);
		KEEP(*(.preinit_array))
		PROVIDE_HIDDEN (__preinit_array_end = .);
		. = ALIGN(4);
		/* init data */
		PROVIDE_HIDDEN (__init_array_start = .);
		KEEP(*(SORT(.init_array.*)))
		KEEP(*(.init_array))
		PROVIDE_HIDDEN (__init_array_end = .);
		. = ALIGN(4);
		/* finit data */
		PROVIDE_HIDDEN (__fini_array_start = .);
		KEEP(*(SORT(.fini_array.*)))
		KEEP(*(.fini_array))
		PROVIDE_HIDDEN (__fini_array_end = .);
		KEEP(*(.jcr*))
		. = ALIGN(4);
		/* All data end */
		__data2_end__ = .;
	} > RAM2
	.bss :
		. = ALIGN(4);
		__bss_start__ = .;
		*(.bss*)
		. = ALIGN(4);
		__bss_end__ = .;
	} > RAM
	.bss2 :
		. = ALIGN(4);
		__bss2_start__ = .;
		*(COMMON)
		. = ALIGN(4);
		__bss2_end__ = .;
	} > RAM2
	.heap (COPY):
		__end__ = .;
		PROVIDE(end = .);
		*(.heap*)
		__HeapLimit = .;
	} > RAM
	/* .stack_dummy section doesn't contains any symbols. It is only
	 * used for linker to calculate size of stack sections, and assign
	 * values to stack symbols later */
	.stack_dummy (COPY):
		*(.stack*)
	} > RAM
	/* Set stack top to end of RAM, and stack limit move down by
	 * size of stack_dummy section */
	__StackTop = ORIGIN(RAM) + LENGTH(RAM);
	__StackLimit = __StackTop - SIZEOF(.stack_dummy);
	PROVIDE(__stack = __StackTop);
	/* Check if data + heap + stack exceeds RAM limit */
	ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
  • Our own sample linker script
/* Linker script to configure memory regions. */
APP_START = DEFINED(APP_START_LOC) ? APP_START_LOC : 0 ;
APP_SIZE = DEFINED(APP_START_LOC) ? 0x80000 - APP_START : 0x80000 ;
FREE_RAM_REQ = DEFINED(MIN_FREE_RAM) ? MIN_FREE_RAM : 0;
MEMORY
  FLASH (rx) : ORIGIN = APP_START, LENGTH = APP_SIZE   /* 512k */
  RAM (rwx)  : ORIGIN = 0x20000000, LENGTH = 0x10000   /*  64k */
  RAM_EXTERN (rwx)  : ORIGIN = 0x60000000, LENGTH = 0x80000   /*  64k */
/* Library configurations */
GROUP(libgcc.a libc.a libm.a libnosys.a)
 *   __exidx_start
 *   __exidx_end
 *   __etext
 *   __data_start__
 *   __init_array_end
 *   __fini_array_end
 *   __data_end__
 *   __bss_start__
 *   __bss_end__
 *   __end__
 *   end
 *   __HeapLimit
 *   __StackLimit
 *   __StackTop
 *   __stack
 *   __Vectors_End
 *   __Vectors_Size
SECTIONS
	.text :
		KEEP(*(.vectors))
		__Vectors_End = .;
		__Vectors_Size = __Vectors_End - __Vectors;
		__end__ = .;
		*(.text*)
		KEEP(*(.init))
		KEEP(*(.fini))
		/* .ctors */
		*crtbegin.o(.ctors)
		*(SORT(.ctors.*))
		*(.ctors)
		/* .dtors */
 		*crtbegin.o(.dtors)
 		*(SORT(.dtors.*))
 		*(.dtors)
		*(.rodata*)
		KEEP(*(.eh_frame*))
		__data_section_table = .;
		LONG(LOADADDR(.data));
		LONG(    ADDR(.data));
		LONG(  SIZEOF(.data));
		__data_section_table_end = .;
		__data_extern_section_table = .;
		LONG(LOADADDR(.data.extern));
		LONG(    ADDR(.data.extern));
		LONG(  SIZEOF(.data.extern));
		__data_extern_section_table_end = .;
		__bss_section_table = .;
		LONG(    ADDR(.bss));
		LONG(  SIZEOF(.bss));
		__bss_section_table_end = .;
		__bss_extern_section_table = .;
		LONG(    ADDR(.bss.extern));
		LONG(  SIZEOF(.bss.extern));
		__bss_extern_section_table_end = .;
	} > FLASH
	.ARM.extab :
	} > FLASH
	__exidx_start = .;
	.ARM.exidx :
	} > FLASH
	__exidx_end = .;
	.copy.table :
		. = ALIGN(4);
		LONG (__etext)
		LONG (__etext2)
	} > FLASH
	.zero.table :
		. = ALIGN(4);
	} > FLASH
	.data.extern : AT (__etext)
		* Place large .data* sections into external SRAM if internal SRAM is insufficient.
		* Such memory arrangement requires initializing .data.extern section in startup file. Check startup fiile in cmsis-core-* for support or not.
		. = ALIGN(4) ;
		__data_extern_start__ = .;
		*(.data.extern*)
		*(.data.$RAM2*)
		*\libtest.a:(.data*)		/*add libcli_service data section to external ram*/
		. = ALIGN(4) ;
		__data_extern_end__ = .;
    } > RAM_EXTERN
   	__etext2 = __etext + ALIGN (SIZEOF(.data.extern), 4);
	.data : AT (__etext2)
		__data_start__ = .;
		*(vtable)
		*(.data*)
		*\libc.a:(.data*)
		. = ALIGN(4);
		/* preinit data */
		. = ALIGN(4);
		/* init data */
		. = ALIGN(4);
		/* finit data */
		KEEP(*(.jcr*))
		. = ALIGN(4);
		/* All data end */
		__data_end__ = .;
	} > RAM
	.bss.extern (NOLOAD):
		* Place large .bss* sections into external SRAM if internal SRAM is insufficient.
		* Such memory arrangement requires initializing .bss.extern section to zero in startup file. Check startup fiile in cmsis-core-* for support or not.
		. = ALIGN(4) ;
		__bss_extern_start__ = .;
		*(.bss.extern*)
		*(.bss.$RAM2*)
		*\libtest.a:(.bss*)			/*add libcli_service data section to external ram*/
		*\libtest.a:(COMMON)		/*add libcli_service data section to external ram*/
		. = ALIGN(4) ;
		__bss_extern_end__ = .;
    } > RAM_EXTERN
	.bss :
		. = ALIGN(4);
		__bss_start__ = .;
		*(.bss*)
		*\libc.a:(.bss*)
		*\libc.a:(COMMON)
		*(COMMON)
		. = ALIGN(4);
		__bss_end__ = .;
	} > RAM
	.heap (COPY):
		__HeapBase = .;
		__end__ = .;
		end = __end__;
		KEEP(*(.heap*))
		__HeapLimit = .;
	} > RAM
		KEEP(*(.stack*))
	} > RAM
Also, Please find below code execution flow of our sample project on which external RAM on EBI is not working
    1) On Board Boot Up, Linker script is calling Reset_Handler from which _start is called
    2) after that main function will be called from main.c file of BSP
    3) Then it will create Hardware Setup, EBI Init, Data Copy and init heap section
    4) After that we have created one sample task to test freeRTOS functionality
So, check above details with linker script and let me know if need any more details from my side regarding same.
