I'm using the FVP Simulator with the Cortex R52 model. Is there any documentation specific to the Cortex R52?
I cannot find a suitable memory map in the fast_models_fvp_rg_100966_1100_00_en.pdf document.
Where is the GIC mapped?
Thank you in advance!
Regards,
Tibor
Hi Tibor,
The PERIPHBASE for the Cortex-R52 is set to 0xAF000000
I think the platform generally follows the VE memory map https://developer.arm.com/docs/dui0837/f/programming-reference-for-ve-fvps/ve-model-memory-map?_ga=2.150041718.1717156407.1561968600-1491088515.1561645087
If you are interested in this platform you can download an evaluation version of the Arm Fast Models and get the source code for the platform. https://developer.arm.com/products/system-design/fast-models
I would be happy to help you get up and running with Fast Models.
Thanks,
Jason
Hello Jason,
thank you for your response. The problem was that the GIC CPU Interface is not memory mapped.
Is there an issue with the GICR_ISENABLER0 register? I noticed that I cannot write to this register with my software or even with a Lauterbach debugger. This one register is also not included in the peripheral description from Lauterbach.
I attempt to write to the register in hypervisor/EL2 level.
To confirm the GIC memory mapping I recommend to try to read a register with a non-zero reset value.
For example, I tried the Cortex-R52 software example which comes with DS-5, the name is startup_Cortex-R52
I put a read of the GICD_CTRL register which has a reset value of 0x50:
/* Display a welcome message via semihosting */ printf("Cortex-R52 bare-metal startup example\n");
gic_ctlr = *((unsigned long *)0xAF000000); printf("ctlr %x\n",gic_ctlr);
I rebuilt the software and ran the FVP again and I can see the value of 0x50 is printed.
$ ./FVP_BaseR_Cortex-R52x1 -a /home/jasand01/startup_Cortex-R52.axf
Cortex-R52 bare-metal startup examplectlr 50Floating point calculation using the FPU...Float result is 0.937500Float result should be 0.937500Insertion sort took 2 clock ticksShell sort took 0 clock ticksQuick sort took 1 clock ticks
Based on this I feel like the GIC is in the memory map at 0xAF000000 and is visible to software.
Can you provide more info about how you are trying to access the GIC which is not working for you?
according to the R52 technical reference manual, the CPU Interface of the GIC is not memory mapped and can only be accessed with mcr or mrc instruction. The GIC distributor and redistributor are memory mapped.
The problem I have is, I cannot write in the specific register of the redistributor: GICR_ISENABLER0, although I can read or write to the other registers of the redistributor.
I need to write to this register in order to enable PPI IRQs from the ARM generic timer. At the moment, SPI IRQs are working fine, but I need to use PPI IRQs also.
Can you please check if you have any issues when writing to this register GICR_ISENABLER0? I tried writing with the Lauterbach debugger, pointer to memory or str instruction. The register should be located at 0xAF10 0100.
I figured it out, there was an additional offset required. Thank you for your support!
