I was wondering if someone knew of a board that had integrated power sensor similar to the odroid XU3. ODROID | Hardkernel
HardKernel discontinued that board.
thanks,
yah
If you can connect an external power meter to measure the Voltage/Current, HiKey board can meet this requirement as it reserves the hardware test points in board. Please see Section "Power Measurements" www.96boards.org/.../HiKey_User_Guide_Rev0.2.pdf If you expect the power sensors are embedded in the board, ARM Juno board may be a choice. Please see community.arm.com/.../tutorial-energy-monitoring-on-juno
