Juno r1 OpenEmbedded System Question
I'm using a Juno r1 board and I'm trying to set up the board with Linaro OPTEE.
I want to deploy the OpenEmbbed system on the board and I found this instruction: Using Linaro's deliverables on Juno .
However, I found the script provided in the link only contains the OE with OPTEE 15.09 while I know the latest OPTEE is 16.06. Is there anyway for me to using OE with OPTEE 16.06 on my board?
Any suggestion is appreciated.
Simon
  • ashwildingarm sorry to trouble you.
    I notice the instruction is updated by you recently so I think you might know the answer, thank you!
  • Hi,
    If you run the script provided in the instructions and choose these options:
    • Build from source
    • Platform: Juno
    • Environment: Linux/Android
    • Kernel: Linaro lsk-3.18-armlt
    • Filesystem: OpenEmbedded [Minimal | LAMP] 15.09
    You will be getting the latest OP-TEE. It's only the OpenEmbedded [Minimal or LAMP] filesystem that is frozen at 15.09.
    Every other component in the software stack will be at its most current version as of when 16.06 was released, i.e.:
    • ARM Trusted Firmware
    • System Control Processor (SCP) firmware
    • OP-TEE
    • U-Boot
    • Linaro lsk-3.18-armlt kernel
    Are all at 16.06, even if the OpenEmbedded [Minimal | LAMP] filesystem is 15.09.
    Hope that helps.
