Hello everybody,
does everyone know whether Raspberry Pi3 can execute 64bit applications?
Even reading some articles, I am uncertain the following things.
Please let me know the answers.
1. Is Raspbian for Raspberry Pi3 compiled by AArch64 architecture?
2. Does the compiler of Raspbian for Raspberry Pi3 generate AArch64 codes?
3. Otherwise, can only AArch32 codes be executable on Raspbian for Raspberry Pi3?
Thank you in advance and best regards,
Yasuhiko Koumoto.
I wouldn't want to stop other people commenting, but... This page is for the development platforms ARM supply directly, rather than ARM platforms generally. Sadly it's hard to make the page title clearer without making it very long :-(
I think you need to ask the Raspberry Pi Community directly. Raspberry Pi 3 on sale now at $35 - Raspberry Pi to get definitive answers.
Obviouly the Pi3 uses an ARM v8 processor implementation that does suport AArch64, so this is all about the state of the supplied software stack. I suspect this quote... "At launch, we are using the same 32-bit Raspbian userland that we use on other Raspberry Pi devices; over the next few months we will investigate whether there is value in moving to 64-bit mode." ...means they are currently using an AArch64 Linux kernel with a 32bit userspace filesystem. Which means you can only run 32but applications.
It's possible to support a "multiarch" filesystem (supporting both AArch32 and AArch64 applications & libs) - but you'd need to ask the Raspberry Pi folks about their plans for this.
MarkN.
Hello Mark,
thank you for your instruction to ask the questions to Raspberry Pi Forum.
I have just posted them to it.
Best regards,
Hello all,
I have gotten the answer from the Raspberry Forum.
At this time, I find there is no 64 bit OS which can be run on Raspberry Pi3.
The people in the forum seems to think there will be little benefits with the 64 bit operation.
Therefore, the reason of adopting the 64 bit core seems to that they want the faster clock speed.
