How to put Juno into Sleep-state
I'm using Linaro Release 15.12 LSK (without OP-TEE) + OpenEmbedded Minimal Filesystem on Juno-r1 Board.
I'm trying to put the Juno board into the Sleep-state referring to ARM Versatile Express Juno r1 Development Platform Technical Reference Manual.
But it seems to reboot and fall into the error state, even if I push the Soft Reset button briefly.
Does anyone know how to put the Juno board into the Sleep-state ?
Thank you for your help.
Moderator edit: As of release 16.05 you can follow the instructions here:
https://community.arm.com/dev-platforms/w/docs/239/system-suspend-to-ram
  • Hi,
    Can you try with the latest juno firmware release [1] ?
    Regards,
    Sudeep
  • Hi Sudeep,
    Great!
    With Linaro 16.05 lateset, Juno could resume from the Suspend State.
    But, I tried continuously to suspend Juno, and could not resume.
    The following is log about PCIe in the first Resume.
         [   18.191690] ata2: SATA link down (SStatus 0 SControl 0)
         [   18.196921] ata1: SATA link down (SStatus 0 SControl 0)
  • Hi taken,
    Sorry for late reply, I couldn't check the message here for a week.
    Do you mean the issue surfaces only when you try to suspend
    resume multiple times continuously ? Can you describe in simple
    words how to reproduce this issue ?
    Regards,
    Sudeep
  • Hi Sudeep,
    Thank you for your reply.
    First, the previous message meant the issue surfaces when I try to suspend & resume twice continuously.
    The steps to reproduce this issue are as follows:
         0. I am using Juno-R1 with Linaro 16.05 latest.
         1. [Set rtc] # echo +5 > /sys/class/rtc/rtc0/wakealarm
         2. [Suspend] # echo mem > /sys/power/state
              (after 5 seconds) Resume
         3. wait about 10seconds
         4. [Set rtc] # echo +5 > /sys/class/rtc/rtc0/wakealarm
         5. [Suspend] # echo mem > /sys/power/state
              (Juno does not resume)
    And I understood it was the cause of this issue that there was no trigger of Resume, because the Suspend process took more than 5 seconds and it was into the Suspend State after RTC interrupt occurred.
    Actually, the issue did not happen when I changed alarm of RTC 10 seconds.
    So I have a question.
         Why does 2nd Suspend process take more than 5 seconds ?
         1st Suspend process does not take 1 second.
         And 2nd Suspend process does not take 1 second if the above steps.3 is "wait a second".
    I would appreciate it if you could answer my question.
    Regards
  • Hi taken,
    Thanks for taking time to explain the details.
    I understand you are using Linaro 16.05 release now, but I want to make know which
    kernel are you trying ? Is it Linaro release or the mainline.
    One possible reason could be the some driver is taking long to complete it's suspend
    and rtc expires before entering suspend.
    I tried with defconfig on v4.7-rc4 and I don't see any issue.
    I need more information on the kernel configuration to check this.
    Regards,
    Sudeep
  • Hi Sudeep,
    Thanks for your prompt reply.
    I tried with defconfig on Linaro 16.05 latest and the issue did not happen as well as v4.7-rc4.
    There is much difference between defconfig and linaro config, so I am trying to check them.
    Regards
  • Hi,
    I reported that the issue surfaces when I try to suspend & resume twice continuously with Linaro 16.05 latest above.
    At that time I used prebuilt binaries (snapshots.linaro.org/.../ : Now not found),
    but the binaries that built from a source code (fetched by the following commands) does not surface the issue.
         # repo init -u https://git.linaro.org/landing-teams/working/arm/manifest -b 16.05 -m pinned-latest.xml
         # repo sync
    Thank you.
  • Hi Taken,
    I am confused. Is the problem solved for you now ?
    Regards,
    Sudeep
  • Hi Sudeep,
    Sorry that I didn't write the conclusion.
    Yes, the problem was solved.
    Thank you so much for all your help.
    Regards
