Can't boot OpenEmbedded on Juno R1
I got an error message "Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,2)".
I'm referring Using Linaro's deliverables on Juno .
And I choose OpenEmbedded Minimal filesystem and prebuild binary juno-latest-oe-uefi.zip .
It was going well with LSK 14.02 preinstalled on Juno.
I want to update software version so that I tried the contents in the article.
Does anyone know how to make this work?
Thanks for the help.
9110.zip
  • Hi,
    The problem is actually that your USB hasn't been correctly formatted. From your fdisk log:
    Device       Boot      Start        End     Blocks  Id  System
    /dev/sdb1p1  *            63     155646      77792   e  W95 FAT16 (LBA)
    /dev/sdb1p2           155648    6291455    3067904  83  Linux
    We should see /dev/sdb1 and /dev/sdb2, but what you actually have is /dev/sdb1p1 and /dev/sdb1p2. We can confirm that this is the problem by looking at your kernel log. We only see this:
    [    6.597568]  sda: sda1
    When we should see an sda2 there as well. Also, your error message was:
    [    8.284227] VFS: Cannot open root device "sda2" or unknown-block(8,2): error -6
    Confirming the above.
    I have a feel that what you've done is this:
    $ sudo dd if=<image_file>.img of=/dev/sdb1 bs=64M
    Whereas what you should have done is this:
    $ sudo dd if=<image_file>.img of=/dev/sdb bs=64M
    i.e. point the of flag of dd at /dev/sdb, *NOT* at /dev/sdb1
    Can you try this and see if that works?
  • Hello,
    It's going well after correcting command.
    Also, I wanted to use 256MB USB memory.
    Now I'm able to do it by create sdb2 partition and copy root filesystem.
    Thank you so much.
