boot-up sequence
The following piece of code is from a reference code provide online.
I would like to know the first line in the reset vector table below.
Address        Description
0x0000 0000    Initial Stack Pointer (SP) value
0x0000 0004    Reset exception
0x0000 0008    NMI
0x0000 000C    Hard fault
0x0000 0010    Memory management fault
0x0000 0014    Bus fault
0x0000 0018    Usage fault
Does the line "Initial Stack Pointer (SP) value" mean that there is a jump address at location 0x0000 0000 which properly configures the stack pointer?
