How to use external sprintf instead of sprintf in libg with GNU Arm Embedded Toolchain Version 10.3-2021.10?
Acutally not only sprintf, there are some other functions have same issue.
I implement sprintf, sscanf, etc in my source code, but get multiple definition error below while linking:
[build] cmd.exe /C "cd . && arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -Ofast -std=gnu11 -Wall -fno-builtin -fno-strict-aliasing -fdata-sections -fms-extensions -ffunction-sections -std=gnu11 -Wall -fno-builtin -fno-strict-aliasing -fdata-sections -fms-extensions -ffunction-sections -fms-extensions -fdiagnostics-color=always -Og -g3 -Wl,--gc-sections -flto --specs=nano.specs    -Wl,-TZ:/vsf.linux/project/cmake/aic8800/linker.ld -Wl,-Map=output.map -mabi=aapcs -march=armv7e-m @CMakeFiles\vsf_linux.rsp -o vsf_linux.elf  && cmd.exe /C "cd /D Z:\vsf.linux\project\cmake\aic8800\build && arm-none-eabi-objcopy -O ihex vsf_linux.elf vsf_linux.hex && arm-none-eabi-objcopy -O binary vsf_linux.elf vsf_linux.bin && cd /D Z:\vsf.linux\project\cmake\aic8800\build && arm-none-eabi-size Z:/vsf.linux/project/cmake/aic8800/build/vsf_linux.elf""
[build] c:/program files (x86)/gnu arm embedded toolchain/10 2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/program files (x86)/gnu arm embedded toolchain/10 2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg_nano.a(lib_a-sprintf.o): in function `_sprintf_r':
[build] sprintf.c:(.text._sprintf_r+0x0): multiple definition of `_sprintf_r'; CMakeFiles/vsf_linux.dir/Z_/vsf.linux/application/vsf_main.c.obj:Z:/vsf.linux/application/vsf_main.c:8: first defined here
[build] c:/program files (x86)/gnu arm embedded toolchain/10 2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/program files (x86)/gnu arm embedded toolchain/10 2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg_nano.a(lib_a-sprintf.o): in function `sprintf':
[build] sprintf.c:(.text.sprintf+0x0): multiple definition of `sprintf'; CMakeFiles/vsf_linux.dir/Z_/vsf.linux/vsf/source/utilities/language_extension/simple_sprintf.c.obj:Z:/vsf.linux/vsf/source/utilities/language_extension/simple_sprintf.c:324: first defined here
[build] collect2.exe: error: ld returned 1 exit status
[build] ninja: build stopped: subcommand failed.
[build] Build finished with exit code 1
But some other functions like malloc etc is OK, I can implement these functions in user space, and they will replace the same function in libg_nano.
0
