armclang: error: Your installation could be misconfigured or corrupted.Check that your licensing and toolkit configuration is set up correctly, using the information available at: developer.arm.com/.../product-and-toolkit-configuration.Information about this error is available at: ds.arm.com/.../lic86 General licensing information is available at: ds.arm.com/.../ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: ':/home/masala/.arm/ds/licenses' - LM_LICENSE_FILE: unset - ARM_PRODUCT_DEF: unset - ARM_PRODUCT_PATH: unset - ARM_TOOL_VARIANT: unset - Product location: product not found - Toolchain location: /opt/arm/developmentstudio-2021.0/sw/ARMCompiler6.16/bin - Selected tool variant: productProduct: unknownComponent: ARM Compiler 6.16Tool: armclang [5dfeab00]
How can i install ARMCompiler6.16 compiler in linux(Ubuntu)
PRAMOD MAURYA said:If you need further help, provide this complete error report to your supplier or license.support@arm.com
did you do that?
