I am working on Cyclone V device with Altera baremetal GCC toolchain in DS-5. Can I continue my work in latest DS Gold Edition with the same toolchain?
Yes, this compiler should continue to just work.Do you use it to build projects inside the IDE? You will likely need to re-add the toolchain (Windows > Preferences > Arm DS > Toolchains, but that is a do once task.
