What happened of r0 after the execution of the above assembly code ?
Hello, which toolchain did you use to generate this instruction? The Arm assembler does not accept it.The "!" notation usually implies "increment-after", and so I may _guess_ that this is attempting to implement the instruction:str r3, [r0] #4
adding 4 (word=4 bytes) to r0, after writing r3 to the original address pointed to by r0.
