What's the actual parameters for enable pac bti mte sel2 in fvp
How to config the fvp model to enable pac bti mte sel2 in fvp
I'm using the lastest fvp version Base_RevC_AEMv8A_pkg
And I have read the guide in fast_models_rm_100964_1180_00_en.pdf
And see the follow params:
PAC:
has_generic_authentication
has_pointer_authentication
subcluster0.has_enhanced_pac
BTI:
has_branch_target_exception
SEL2:
has_secure_el2
MTE:
memory_tagging_support_level
But what's the actual param to enable it?
Is it this?  clusterx.xxx=1
cluster0.has_secure_el2=1
cluster1.has_secure_el2=1
  • Is the follow configure right?
    diff --git a/fvp/run_model.sh b/fvp/run_model.sh
    index 787d769..413693a 100644
    --- a/fvp/run_model.sh
    +++ b/fvp/run_model.sh
    @@ -110,7 +110,16 @@ else
    fi
    cores="-C cluster0.NUM_CORES=$CLUSTER0_NUM_CORES \
    - -C cluster1.NUM_CORES=$CLUSTER1_NUM_CORES"
    + -C cluster1.NUM_CORES=$CLUSTER1_NUM_CORES \
    + -C cluster0.has_pointer_authentication=2 \
    + -C cluster1.has_pointer_authentication=2 \
    + -C cluster0.has_secure_el2=2 \
    + -C cluster1.has_secure_el2=2 \
    + -C cluster0.has_branch_target_exception=2 \
    + -C cluster1.has_branch_target_exception=2 \
    + -C cluster0.memory_tagging_support_level=2 \
    + -C cluster1.memory_tagging_support_level=2
