`bkpt` instruction for semihosting request is ignored when optimization level is 1
Hello everyone,
I'm fiddling with the RP2040 in bare metal for fun and study. I have implemented a simple function that prints a message on the openocd terminal via semihosting:
void semihosting_write(const char *string, uint16_t len) {
    uint32_t args[3] = {1, (uint32_t)string, len};
    invoke_semihosting(SYS_WRITE, args);
static void invoke_semihosting(uint32_t reason, uint32_t *args) {
    asm volatile("mov r0, %[reason] \n"
                   "mov r1, %[args]\n"
                   "bkpt 0xAB      \n"
                   :                                      /* outputs */
                   : [reason] "r"(reason), [args] "r"(args) /* inputs */
                   : "r0", "r1"                           /* clobber */
My issue is that this code works as long as the optimization level is either `-O0` or `-Og`; as soon as I raise it to `-O1` the messages aren't delivered anymore. The application keeps going, but no log is shown on openocd.
I've stepped through the assembly code and in both cases `bkpt` is executed with the correct code and the right parameters in `r0` and `r1`. What could be the issue?
