Bug: Floating point rounding errors in implicitly linked amath.so
The NVIDIA libcudacxx project does verification of both CPU and GPU results to ensure that computations are hopefully repeatable from either processor. We've determined that there is some rounding error in the implicitly linked amath.so. Specifically when testing cbrtf. I did not determine other exponent cmath functions to have the same issue.
I am unable to attach C++ files, so the code is pasted below. Sorry if there are any formatting issues.
FAILING CASE
Compiled with:
$ /home/coder/armclang/24.10/arm-linux-compiler-24.10.1_Ubuntu-22.04/bin/armclang++ test.cpp \
  -std=c++20 -O3 -nostdlib -L../armclang/24.10/arm-linux-compiler-24.10.1_Ubuntu-22.04/lib -lc -lamath -lgcc
$ ldd a.out
  linux-vdso.so.1 (0x00007daa87514000)
  libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x00007daa86ae0000)
  /lib/ld-linux-aarch64.so.1 (0x00007daa874c0000)
  libamath.so => not found
$ LD_LIBRARY_PATH=/home/coder/armclang/24.10/arm-linux-compiler-24.10.1_Ubuntu-22.04/lib ./a.out
0X40000000 (expected)
0X40000001 (result)
PASSING CASE
Compiled with:
  -std=c++20 -O3 -nostdlib -L../armclang/24.10/arm-linux-compiler-24.10.1_Ubuntu-22.04/lib -lc -lm -lgcc
$ ldd a.out
    linux-vdso.so.1 (0x0000717b8130b000)
    libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000717b808d0000)
    libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000717b80830000)
    /lib/ld-linux-aarch64.so.1 (0x0000717b812b0000)
$ ./a.out
0X40000000 (result)
#include <cmath>
#include <stdio.h>
int main();
extern "C" void _start() {
  main();
  exit(0);
int main() {
  using T = float;
  volatile float val = 64.0f / 8.0f;
  auto result = (float)cbrtf(val);
  auto expected = (float)T(2);
  auto print4 = [](const char* v) {
    printf("%#.2hhX%.2hhX%.2hhX%.2hhX\n", v[3], v[2], v[1], v[0]);
  print4((const char*)&expected);
  print4((const char*)&result);
  return 0;
  • Hello and thank you for reporting this.
    First of all, we apologize if this is not stated more clearly in our documentation, but such variations in output (here 1 ULP) are expected, as they are within the tolerance set for amath scalar routines, which defaults to 3.5 ULP. But if this case can be improved at a negligible cost, then it might be considered in a future release.
    It is worth noting that many important amath scalar routines still have much better accuracy than the advertised 3.5 ULP, and maximum errors are effectively between 0.5 and 1ULP.
    If you require higher accuracy for scalar routines we recommend relying on another libm provider (e.g. system libc), which can easily be achieved at link time without losing the ability to use amath vector symbols.
    Let us know if you have any more questions, or if we can help further.
    Kindest,
