arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi issue with GCOV
I use GCOV for test coverage in project. I am following instructions for freestanding environment (https://gcc.gnu.org/onlinedocs/gcc/Freestanding-Environments.html).
Below are the flags i use.
CFLAGS += -O0 -fprofile-arcs -ftest-coverage -fprofile-info-section
LFLAGS += -lgcov --coverage
With these flags, thigs works fine with toolchain version 12.3 (arm-gnu-toolchain-12.3.rel1-x86_64-arm-none-eabi) but i am facing below error if i upgrade to toolchain version 14.2 (arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi).
/opt/new/SM/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld: /opt/new/SM/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/14.2.1/thumb/v8-m.main+fp/softfp/libgcov.a(_gcov.o): in function `gcov_read_bytes':
libgcov-driver.c:(.text.gcov_read_bytes+0x10): undefined reference to `fread'
After a bit google, i found that if i pass '-lgcov --coverage' before '-lc' in linking, then my problem is fixed.
Need help to understand why such changes are not required for toolchain version 12.3 ?
