arm-none-eabi-gdb extremely slow to load symbols
since a few releases of the ARM GCC toolchain, GDB is extremely slow to load the symbols on Windows (at least since the GCC 11 release).
It usually takes 5-10s to load them the first time on a specific ELF file.
After that, it may be instant, there is probably some caching made by GDB. It gets slow again a few minutes later on the same file.
I usually have to use GDB from the 7-2018-q2 release to get it working with a fast symbols loading.
Unfortunately the ELF generated by the latest GCCs tend to crash this old GDB, making this solution unreliable now.
This seems to be a Windows specific problem (I didn't tested the Linux version, but it is probably not happening otherwise this bug would be fixed already).
To reproduce:
 - use arm-gnu-toolchain-14.2.rel1-mingw-w64-i686-arm-none-eabi.zip from the ARM website (on Windows 10 / 11)
 - download any embedded .elf, for example https://github.com/jonvolk/stm32-slcan/blob/master/stm32-slcan.elf
 - on the shell (any, the Windows cmd.exe will do), type: arm-none-eabi-gdb.exe stm32-slcan.elf
 - see how much time it takes to load the symbols before gdb is ready
Thanks,
Florent
