Hi,I am trying to download Arm Compiler for Embedded (ACOMPE) but keeps failing with below messages.Not sure where I should sign this EULA agreement.System ErrorWe apologise for the inconvenience but an unexpected error occurred processing your application. Please try again shortly.WarningPlease sign EULA agreement.(1003)Best regards,Jung Ik Moon
Opened a case for this issue. (Case Number: 03458616)
Hello
I have moved this post to the Compilers and Libraries forum. If you find the resolution through the support case, please share it here for others to learn from if you are permitted.
Many thanks
Oli
Arm Community Manager
Is it resolved?
I am facing the similar. When I tried to download ARM Compiler 6, it said in the dowload hub page that
We could not retrieve the data.
Try again later or contact support.
Didn't get the answer yet.
H all, quick update from Arm. We are currently looking into this and an update will be provided as soon as possible.
Many thanks for you patience
Hi Jung Ik Moon and Wayne C.
Please can you try downloading again? I have been informed the issue has been identified and hopefully resolved.
Let me know how you get on.
Hi Oliver Beirne,I have retried with both Chrome and Edge but still the same.==========System ErrorWe apologise for the inconvenience but an unexpected error occurred processing your application. Please try again shortly.WarningPlease sign EULA agreement.(1003)Best regards,Jung Ik Moon
Ok I will feed that back into our support team now. Thanks again for you patience while we work on this.
I have heard back from Support and they would like to check the following:
Please let me know how you get on and if you have any questions.
Hi Oliver Beirne,As soon as our firewall team opens na3.docusign.net for me, I will try again and let you know.Best regards,Jung Ik Moon
Hi all,After opening the firewall, the issue is now resolved.Best regards,Jung Ik Moon
Thanks for letting me know. I will pass this along to the Support team. Thanks again for your help and patience helping us resolve this issue.
