severity: urgent, may impact if we could use these ARM sram in Project I6F for UMC22ULPULL tapeout
1. DRC failed on rule “ EXTRA_JOG_RULE_PMETGMK”
2. DRC deck version: G-DF-LOGIC_MIXED_MODE22N-ULP_ULL-1P7M0T0A0C1U-CALIBRE-DRC-1.7_P1
3. sram compiler : rf_sp_hde_svt_mvt , rf_2p_hdc_svt_mvt
4. sram compiler version:
High Density single Port register File SVT MVT Compiler Release Notes (UM31CD001)
Release description :
Product Name : rf_sp_hde_svt_mvt
SAP Code : UM31CD001
Foundary :UMC
ARM Version : r0p1-02eac0
Date : 12-04-2022
High Density Two Port register File SVT MVT Compiler Release Notes (UM31CE000)
Production description :
Product Name : rf_2p_hdc_svt_mvt
SAP Code : UM31CE000
SRAM configuration
Instance Name : sram1p256x148w16_SP12_hd1r_gl_H_PG1_AM_M2B1_9_3_1076_0p660
Words: 256, Bits : 148, Mux : 2, Drive : 6, Write Mask : On, Write Thru : Off, Extra Margin Adjustment : On, Test Muxes : Off, Power Gating : On, Retention : On, Pipeline : Off, Read Disturb Test : Off
Instance Name : sram2p256x133_hd2r_gl_H_PG1_AM_M2B2_9_3_720_0p891
Words: 256, Bits : 133, Mux : 2, Drive : 6, Write Mask : Off, Write Thru : Off, Extra Margin Adjustment : On, Redundary : Off, Test Muxes : Off, Power Gating : On, Retention : On, Pipeline : Off, Read Disturb Test : Off
Thank you!! I submit a support case to the web site https://developer.arm.com/support
03386374 – UMC22ULPULL SRAM compiler rf_sp_hde_svt_mvt , rf_2p_hdc_svt_mvt DRC failed issue – opened
