I tried to use the last version of CMSIS to compute a FIR filter using DSP function on a CORTEX-M33. It appears that there is not precompiled library with this version.
Then, I imported this lib in IAR and compiled it with speed optimization. For a 81 taps FIR with 256 elements, the number of cycles required is about 150,000 cycles which is twice higher than expected.
I tried to do the same on CubeIDE (GCC) which precompiled library and I got VFP register arguments errors. By adding some compilation argument -mfloat-abi=hard and -mfpu the error still appears. I'm not sure I used the correct version of FPU.
Is there an official way to compile the CMSIS DSP library for CORTEX-M33 on GCC or IAR?
Best Regards,Gwénolé
