Hi
I want to recompile A53 test case.
In MP030-BU-50000-r0p4-52rel2/cortexa53/logical/testbench/execution_tb/README,
I should install arm-none-eabi and aarch64-none-elf. It provide a manual way to download, config and make the toolchain.
But I met the error in Centos 7 OS.
Then I search the arm-none-eabi and aarch64-none-elf toolchain and found it in
https://developer.arm.com/tools-and-software/open-source-software/developer-tools/gnu-toolchain/gnu-a/downloads
I downloaded and intsalled the newest gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf and gcc-arm-10.2-2020.11-x86_64-arm-none-eabi.
When I use these toolchain, I meet the following err:
[austin@host220 tests]$ make aarch64/dhrystone -B [CC ] common/dhrystone/dhry_2.c [CC ] common/dhrystone/dhry_1.ccommon/dhrystone/dhry_1.c:39:12: warning: 'dont_print' initialized and declared 'extern' 39 | extern int dont_print __attribute__((weak)) = 1; | ^~~~~~~~~~common/dhrystone/dhry_1.c: In function 'main':common/dhrystone/dhry_1.c:246:42: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] 246 | printf (" Ptr_Comp: %d\n", (int) Ptr_Glob->Ptr_Comp); | ^common/dhrystone/dhry_1.c:257:42: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] 257 | printf (" Ptr_Comp: %d\n", (int) Next_Ptr_Glob->Ptr_Comp); | ^ [CC ] common/shared/output_trickbox.c [CC ] common/shared/retarget-gcc.ccommon/shared/retarget-gcc.c: In function '_write':common/shared/retarget-gcc.c:62:5: warning: implicit declaration of function 'output_char'; did you mean 'putchar'? [-Wimplicit-function-declaration] 62 | output_char(buf[i++]); | ^~~~~~~~~~~ | putchar [ASM ] aarch64/shared/bootcode.s [ASM ] aarch64/shared/stackheap.s [ASM ] aarch64/shared/vectors.s [ASM ] aarch64/shared/pagetables.s [LINK] aarch64/dhrystone/dhry_2.o/opt/arm_toolchain/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /opt/arm_toolchain/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/lib/libc.a(lib_a-signalr.o): in function `_getpid_r':/tmp/dgboter/bbs/build02--cen7x86_64/buildbot/cen7x86_64--aarch64-none-elf/build/src/newlib-cygwin/newlib/libc/reent/signalr.c:83: undefined reference to `_getpid'collect2: error: ld returned 1 exit statusmake: *** [aarch64/dhrystone/dhrystone.elf] Error 1[austin@host220 tests]$
arm-none-eabi have the same problem.
How to fix it?
