I have a app.sct ARMLINK script file with overlay section:
OVERLAY_A ImageLimit(RAM_DATA_ON) OVERLAY { *(.app.overlay_a) }
I'm trying to achive the same result with gcc linker script as follows:
OVERLAY SIZEOF(RAM_DATA_ON) : { OVERLAY_A { *(.app.overlay_a) } }
ARMLINK automatically defines these symbols for overlay section:
Image$$OVERLAY_A$$ZI$$Length
Image$$OVERLAY_A$$RW$$Length
Image$$OVERLAY_A$$RO$$Length
Image$$OVERLAY_A$$RW$$Base
Image$$OVERLAY_A$$RO$$Base
Load$$OVERLAY_A$$RW$$Base
Load$$OVERLAY_A$$RO$$Base
which are actively used by application.
How to correctly define these in ld script file overlay? How do I get RO, RW, ZI parts from .app.overlay_a input section?
Hi Alexey,
So, unlike armlink, GNU ld does not automatically create these linker-defined symbols around sections. Instead, those need to be defined specifically in the linker script by doing something like:
_my_data_start_marker_ = . ; .data: { *(.data*) } _my_data_end_marker_ = . ;
which would give you the equivalent of:
Image$$something$$RW$$BaseImage$$something$$RW$$Limit
and then the equivalent of Image$$something$$RW$$Length would be `_my_data_end_marker_ - _my_data_start_marker_`
Also note that GNU uses different naming for:RO: .textRW: .dataZI: .bss
As such, it looks like you'll have to break down the `*(.app.overlay_a)` into 3: one for the .text, one for .bss and one for .data and create symbols around them as `symbol = .`.
Hope this helps!
(I think these might be created as `*(.app.overlay_a.data) , *(.app.overlay_a.text) , *(.app.overlay_a.bss)` ... I don't have a linker script and build to check this at hand rn and it may depend on how you've created `.app.overlay_a`, so you might have to fiddle with that until it works)
Thanks. Hope *(.app.overlay_a.data) and (.app.overlay_a.text) will work.
