How can Gcc work with itcm of stm32h7x
when i use the ITCM of stm32h743,in linkscript,i add new section as:
  _sitcm_addr = LOADADDR(.ItcmRam);
  _svtor_addr = LOADADDR(.isr_vector);
  _vtor_size = 0x400; /*SIZEOF (.isr_vector)*/
  .ItcmRam :
    . = _vtor_size;    /*reserved for vector table*/
    . = ALIGN(4);
    _sitcm = .;        /* create a global symbol at ITCM start */
    *(.ItcmRam);       /* ram_itcm */
    . = ALIGN(4);
    _eitcm = .;        /* define a global symbol at ITCM end */
  } >ITCMRAM AT> FLASH
where ITCMRAM in memory
MEMORY
DTCMRAM (xrw)      : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D1 (xrw)      : ORIGIN = 0x24000000, LENGTH = 512K
RAM_D2 (xrw)      : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw)      : ORIGIN = 0x38000000, LENGTH = 64K
ITCMRAM (xrw)      : ORIGIN = 0x00000000, LENGTH = 64K
FLASH (rx)      : ORIGIN = 0x8000000, LENGTH = 2048K
in startup file ,i copy .ItcmRam section content in flash to itcm ram after .bss section,like this
CopyItcmInit:
  ldr  r3, =_sitcm_addr
  ldr  r3, [r3, r1]
  str  r3, [r0, r1]
  adds  r1, r1, #4
LoopCopyItcmInit:
  ldr  r0, =_sitcm
  ldr  r3, =_eitcm
  adds  r2, r0, r1
  cmp  r2, r3
  bcc  CopyItcmInit
in source file ,i make some function in ItcmRam section like
void TestItcm(void) __attribute__((section(".ItcmRam")));
in main(){
TestBF();
TestItcm();
TestAF()
it works right that can go into the function TestItcm,but then can not get back to main to run the next TestAf function
in the TestItcm function ,it works correctly untill  return , and not retrun to main instead of into "HardFault_Handler".
IS there some method to use stm32h7x's itcm ram with GCC? thanks!
0
