I've asked this Q in Stack-Overflow, but no help... ;-(
I've encountered a strange behavior which blocks a sort of journaling file-system flash architecture I'm working on. I'm trying to position an executable at a specific 8-byte aligned address, by modifying the MEMORY/FLASH/ORIGIN field in my linker-script. Everything is fine till I add a call to printf() - then the start address is 16-byte aligned.
MEMORY/FLASH/ORIGIN
printf()
I'm using the minimal semihost sample application from the gcc-arm-none-eabi toolchain (gcc-arm-none-eabi-9-2020-q2-update-win32). I changed the MEMORY/FLASH/ORIGIN field in the linker-script to 8.
Generating the HEX-file: arm-none-eabi-objcopy.exe -O ihex .\semihost-CM4.axf .\semihost-CM4.hex Thanks.
One can download the project: https://drive.google.com/file/d/1ODcoypaBeTw38BqWnysbm4PuPgaGIRuw/view?usp=sharing
$ make clean $ make
