I am getting syntax error which I try to link the Scatter file. I am using arm - GCC toolchain.
What is wrong is not specifed.
The same is working for arm compiler but not for arm gcc
GCC doesn't use "Scatter" files?
Hello,Can you give us the exact error sentence you have?and environment details.Regards
core said:The same is working for arm compiler but not for arm gcc
You mean the ARM Linker ?
As previously suggested, the ARM Linker and the GCC Linker are entirely different tools - there is no reason to expect that a Scatter file for the ARM Linker is going to work with the GCC Linker.
Documentation for the GCC Linker: https://gcc.gnu.org/onlinedocs/gcc/Link-Options.html
GCC Linker Command Language, Scripts, etc:
https://ftp.gnu.org/old-gnu/Manuals/ld-2.9.1/html_chapter/ld_3.html
