I have an IPOPT optimization library that is using MKL(Math Kernel Library) like BLAS, LAPACK, MUMPS in Intel x86 Arch. Now I'm planning to port it to ARM-based Nvidia Pegasus. I'm doubtful about its compilation. I would like to know how can I make use of MKL in ARM, if not what will be the workaround. Kindly help
Hi Vimal
I have moved this thread to the Arm Compilers forum where someone will hopefully be able to help you.
Oli from the Community Team
You may wish to use the Arm Performance Libraries
developer.arm.com/.../arm-performance-libraries
