gcc with neon
Hi
I add a piece of code in multimedia.
It makes data in array reverse.
It works, but when I add -O2 or -O3 the result is error and vmov with -O2 ,-O3 create illegal instruction.
I don't understand...
Is this a gcc bug??
asm volatile
  "pld [%0, #0xFFF];\n\t\
  vldm %0!,{d0-d3};\n\t\
  vswp.32 d0,d3;\n\t\
  vswp.32 d1,d2;\n\t\
  VREV64.32 q0, q0;\n\t\
  VREV64.32 q1, q1;\n\t\
  vstm %1!,{d0-d3};"
  :"r"(data),"r"(coeff),"r"(tmp),"r"(sum),"r"(ptr)
  :"d0", "d1","d2","d3","d4","d5","d6","d7"
asm volatile
  vldm %1!,{d4-d7};\n\t\
  VMUL.I32 d0,d0,d4;\n\t\
  VMUL.I32 d1,d1,d5;\n\t\
  VMUL.I32 d2,d2,d6;\n\t\
  VMUL.I32 d3,d3,d7;\n\t\
  VADD.I32 d0,d0,d1;\n\t\
  VADD.I32 d2,d2,d3;\n\t\
  VADD.I32 d0,d0,d2;\n\t\
  VMOV %2,%3,d0;\n\t\
  add %3,%3,%2;\n\t\
  str %3,[%4]"
  • If your code is legal, I think this is an error in GCC.
    My guess is that the optimizer might not recognize the instructions properly and thus might mess up the result.
    I would recommend writing the assembly code in a separate file ending in .S, and then call it as a subroutine from C, when you need it.
    -Eg. you would probably prefer a block of repeated assembly instructions / macros, so you don't have a small 'inner loop', which would waste time on branching / subroutine calling.
    That would shield your code from the optimizer.
    If you choose this solution, you can use the GNU Assembler's macros (.macro and .endm) and repeat code blocks using .rept and .endr...
    Note: Although used by GCC, the GNU Assembler (GAS) is not a part of GCC; it's a completely different tool.
  • Hi Ching Hsiung Yu,
    it seems to depend on the compiler version. GCC 4.3.1 could compile the code successfully. However, GCC 4.9.3 could not recognize the neon instructions. The correspondent assembler with GCC 4.9.3 could recognize those neon instructions. So you should better write the code not by the inline assembler but by the pure assembly code as jebsbauer says.
    Best regards,
    Yasuhiko Koumoto.
  • It seems strange gcc cannot use neon....
  • Of course, it is the story of the inline assembler. I used your source code for assembling.
    Here are the procedures.
    $ cat temp.c
    main()
    float *data;
    float *coeff;
    float tmp,sum;
    float *ptr;
    asm volatile
      vswp.32 d0,d3;\n\t\
      vswp.32 d1,d2;\n\t\
      vstm %1!,{d0-d3};"
    asm volatile
      VMOV %2,%3,d0;\n\t\
      add %3,%3,%2;\n\t\
      str %3,[%4]"
    $ arm-elf-gcc -o temp.out -O3 -mfpu=neon temp.c -nostdlib
    /cygdrive/d/arm-tools/bin/../lib/gcc/arm-elf/4.3.1/../../../../arm-elf/bin/ld: warning: cannot find entry symbol _start; defaulting to 00008000
    $ arm-elf-objdump.exe -D temp.out
    temp.out:    file format elf32-littlearm
    Disassembly of section .text:
    00008000 <main>:
        8000:      e52d4004        push    {r4}            ; (str r4, [sp, #-4]!)
        8004:      e3a0c000        mov    ip, #0  ; 0x0
        8008:      e3a04000        mov    r4, #0  ; 0x0
        800c:      f5d4ffff        pld    [r4, #4095]
        8010:      ecb40b08        vldmia  r4!, {d0-d3}
        8014:      f3b20003        vswp    d0, d3
        8018:      f3b21002        vswp    d1, d2
        801c:      f3b80040        vrev64.32      q0, q0
        8020:      f3b82042        vrev64.32      q1, q1
        8024:      eca40b08        vstmia  r4!, {d0-d3}
        8028:      f5d4ffff        pld    [r4, #4095]
        802c:      ecb40b08        vldmia  r4!, {d0-d3}
        8030:      ecb44b08        vldmia  r4!, {d4-d7}
        8034:      f2200914        vmul.i32        d0, d0, d4
        8038:      f2211915        vmul.i32        d1, d1, d5
        803c:      f2222916        vmul.i32        d2, d2, d6
        8040:      f2233917        vmul.i32        d3, d3, d7
        8044:      f2200801        vadd.i32        d0, d0, d1
        8048:      f2222803        vadd.i32        d2, d2, d3
        804c:      f2200802        vadd.i32        d0, d0, d2
        8050:      ec5ccb10        vmov    ip, ip, d0
        8054:      e08cc00c        add    ip, ip, ip
        8058:      e584c000        str    ip, [r4]
        805c:      e8bd0010        pop    {r4}
        8060:      e12fff1e        bx      lr
    Disassembly of section .comment:
    00000000 <.comment>:
      0:  43434700        movtmi  r4, #14080      ; 0x3700
      4:  4728203a        undefined
      8:  2029554e        eorcs  r5, r9, lr, asr #10
      c:  2e332e34        mrccs  14, 1, r2, cr3, cr4, {1}
      10:  Address 0x00000010 is out of bounds.
    Disassembly of section .ARM.attributes:
    00000000 <_stack-0x80000>:
      0:  00000f41        andeq  r0, r0, r1, asr #30
      4:  61656100        cmnvs  r5, r0, lsl #2
      8:  01006962        tsteq  r0, r2, ror #18
      c:  00000005        andeq  r0, r0, r5
    $ arm-elf-gcc -v
    Using built-in specs.
    Target: arm-elf
    Configured with: ../gcc-4.3.1/configure --target=arm-elf --with-gmp=/usr/local/gmp-4.2.2 --with-mpfr=/usr/local/mpfr-2.3.1 --prefix=/usr/local/arm-tools --enable-languages=c --disable-libssp
    Thread model: single
    gcc version 4.3.1 (GCC)
    Are there any strange parts?
    Best regards,
    Yasuhiko Koumoto.
