Clang static analyzer produces linker error L6007U
I'm using Keil uVision v5.29 and ARM compiler v6.13.1 (ArmClang).  I was looking for a static code analyzer and found that Clang includes a static analyzer that is run with the --analyze option (see http://clang.llvm.org/docs/UsersManual.html).  I added the --analyze option to my project's compiler command line (Options for Target -> C/C++ (AC6) -> Misc Controls) and it seems to work, at least partially.  When I rebuild I get several new and appropriate compiler warnings that were not detected before.  However, now the linking fails with "project.axf: error: L6007U: Could not recognize the format of file .\objects\project\sourcefile.o."
Does the Clang static analyzer work with Keil uVision, ArmClang, and ArmLink?
Is adding --analyze to the [Options for Target -> C/C++ (AC6) -> Misc Controls] field the proper way to invoke the static analyzer?
Why do I get linker error L6007U with the --analyze compiler option and is there a way to avoid this error while using the Clang static analyzer?
0
