Hello!
I am trying to make a bin image of my application for me to flash it into my ARM Cortex M0 processor. I have succeeded in outputting an elf image, but failed with converting it to a bin with the arm-none-eabi-objcopy tool. Here is the line from the makefile:
%.$(TARGET).bin: %.$(TARGET).elf $(TRACE_OBJCOPY) $(Q)$(OBJCOPY) -O binary $< $@
Here is all of my Makefile.
#Set the toolchain program names. CC = arm-none-eabi-gcc AR = arm-none-eabi-ar AS = arm-none-eabi-as LD = arm-none-eabi-gcc OBJCOPY = arm-none-eabi-objcopy #Set the processor related flags (common to C code and linker). CPUFLAGS += -mcpu=cortex-m0plus -mthumb -mfloat-abi=soft CPUFLAGS += -specs=nano.specs -specs=nosys.specs #Set common C code flags. CFLAGS += -D__SAMD21G18A__=1 CFLAGS += -Wall -g -ffunction-sections -fdata-sections -O2 CFLAGS += $(CPUFLAGS) #Set the linker flags. LDFLAGS += -Wl,--gc-sections LDFLAGS += -Wl,-T$(CONTIKI_CPU)/atsamd21g18a.ld -lc LDFLAGS += -Wl,-Map=$(OBJECTDIR)/$(CONTIKI_PROJECT).map LDFLAGS += $(CPUFLAGS) #Configure the CPU path and source files. CONTIKI_CPU_DIRS += . CONTIKI_CPU_DIRS += dev CONTIKI_CPU_DIRS += samd21dfp/ CONTIKI_CPU_DIRS += samd21dfp/samd21a/include CONTIKI_CPU_DIRS += samd21dfp/samd21a/include/component CONTIKI_CPU_DIRS += samd21dfp/samd21a/include/instance CONTIKI_CPU_DIRS += ../arm/common/CMSIS CONTIKI_SOURCEFILES += samd21-startup.c clock.c rtimer-arch.c CONTIKI_SOURCEFILES += rtc.c evsys.c PROJECT_OBJECTFILES += ${addprefix $(OBJECTDIR)/,$(CONTIKI_TARGET_MAIN:.c=.o)} #Add objcopy to the verbosity control. ifeq ($(V),1) TRACE_OBJCOPY = else TRACE_OBJCOPY = @echo " OBJCOPY " $@ endif #Don't treat project object files and syscalls.o as intermediates (avoids deletion and recompiling). .SECONDARY: $(PROJECT_OBJECTFILES) .SECONDARY: $(OBJECTDIR)/syscalls.o #This rule creates a .bin image from the .elf file. Its output is made precious so it doesn't get #deleted even if it's an intermediate. .PRECIOUS: %.$(TARGET).bin %.$(TARGET).bin: %.$(TARGET).elf $(TRACE_OBJCOPY) $(Q)$(OBJCOPY) -O binary $< $@ .PRECIOUS: %.$(TARGET).elf %.$(TARGET).elf: %.co $(PROJECT_OBJECTFILES) $(PROJECT_LIBRARIES) contiki-$(TARGET).a \ $(OBJECTDIR)/syscalls.o $(CONTIKI_SOURCEFILES) $(TRACE_LD) $(Q)$(CC) $(LDFLAGS) -Wl,--section-start=.text=0x2000 $(TARGET_STARTFILES) ${filter-out %.a,$^} \ ${filter %.a,$^} $(TARGET_LIBFILES) -o $@ -I$(CONTIKI_CPU_DIRS) -I$(OBJECTDIR) #Add the .elf file to the clean list. CLEAN += *.$(TARGET).elf *.$(TARGET).bin
