md_apply_fix when using trick to simulate __attribute__(at())
I am using a "trick" to simulate __attribute__(at()) from the ARM toolchain in GCC. I have a macro defined as
Then I have something like the following:
When I use this with compilers targeted at arm-none or arm-elf, it works fine and I get the desired result that I can access the "thing" structure instance and it accesses the correct memory location.
However, when I use this with aarch64-none or aarch64-elf compilers, I get the following:
Is anyone aware of any workaround that would me to achieve the result I am looking for? I do not have the option of modifying the linker script for this.
0
