I am trying to build a C++ OpenCV project with ARM compiler 6 in ARM development studio ide. I already, downloaded version 3.2.0 from the GitHub repository of OpenCV and built it for the MinGW compiler using CMake GUI in windows. When I configure my project to use MinGW, I can cross-compile my code an generate the axf file without any problem. However, when I use ARM compiler 6 I'm getting the build report attached below., my questions are, what can I do to resolve the reported errors ? Do I need to re-build the OpenCV library for ARM compiler 6? If so which generator and platform should I choose in CMake GUI?
17:22:07 **** Incremental Build of configuration Debug for project Stereo_Circular_Eclipse **** make all 'Building file: ../depth/depth.cpp' 'Invoking: Arm C++ Compiler 6' armclang.exe --target=aarch64-arm-none-eabi -I"C:\openCV\build_opencv\install\include" -xc++ -fno-exceptions -O0 -g -MD -MP -c -o "depth/depth.o" "../depth/depth.cpp" armclang: warning: Your license for feature ds_suite_eval will expire in 30 days [-Wlicense-management] armclang: warning: Your license for feature ds_compiler_eval20191 will expire in 30 days [-Wlicense-management] In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:40: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/params.h:33: C:\openCV\build_opencv\install\include\opencv2/flann/any.h:268:42: error: cannot use 'throw' with exceptions disabled if (policy->type() != typeid(T)) throw anyimpl::bad_any_cast(); ^ C:\openCV\build_opencv\install\include\opencv2/flann/any.h:277:42: error: cannot use 'throw' with exceptions disabled if (policy->type() != typeid(T)) throw anyimpl::bad_any_cast(); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:40: C:\openCV\build_opencv\install\include\opencv2/flann/params.h:78:9: error: cannot use 'throw' with exceptions disabled throw FLANNException(cv::String("Missing parameter '")+name+cv::String("' in the parameters given")); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:41: C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:113:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Invalid index file, cannot read"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:117:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Invalid index file, wrong signature"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:151:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Cannot read from file"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:160:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Cannot read from file"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:165:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Cannot read from file"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:176:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Cannot read from file"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/saving.h:181:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Cannot read from file"); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:36: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/kdtree_index.h:46: C:\openCV\build_opencv\install\include\opencv2/flann/random.h:110:14: warning: 'random_shuffle<std::__1::__wrap_iter<int *> >' is deprecated [-Wdeprecated-declarations] std::random_shuffle(vals_.begin(), vals_.end()); ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\algorithm:3067:1: note: 'random_shuffle<std::__1::__wrap_iter<int *> >' has been explicitly marked deprecated here _LIBCPP_DEPRECATED_IN_CXX14 void ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\__config:979:39: note: expanded from macro '_LIBCPP_DEPRECATED_IN_CXX14' # define _LIBCPP_DEPRECATED_IN_CXX14 _LIBCPP_DEPRECATED ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\__config:962:48: note: expanded from macro '_LIBCPP_DEPRECATED' # define _LIBCPP_DEPRECATED __attribute__ ((deprecated)) ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:38: C:\openCV\build_opencv\install\include\opencv2/flann/kmeans_index.h:372:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Unknown algorithm for choosing initial centers."); ^ C:\openCV\build_opencv\install\include\opencv2/flann/kmeans_index.h:435:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Branching factor must be at least 2"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/kmeans_index.h:536:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Number of clusters must be at least 1"); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:41: C:\openCV\build_opencv\install\include\opencv2/flann/hierarchical_clustering_index.h:384:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Unknown algorithm for choosing initial centers."); ^ C:\openCV\build_opencv\install\include\opencv2/flann/hierarchical_clustering_index.h:467:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Branching factor must be at least 2"); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:42: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/lsh_index.h:49: C:\openCV\build_opencv\install\include\opencv2/flann/lsh_table.h:353:10: warning: 'random_shuffle<std::__1::__wrap_iter<unsigned long *> >' is deprecated [-Wdeprecated-declarations] std::random_shuffle(indices.begin(), indices.end()); ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\algorithm:3067:1: note: 'random_shuffle<std::__1::__wrap_iter<unsigned long *> >' has been explicitly marked deprecated here _LIBCPP_DEPRECATED_IN_CXX14 void ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\__config:979:39: note: expanded from macro '_LIBCPP_DEPRECATED_IN_CXX14' # define _LIBCPP_DEPRECATED_IN_CXX14 _LIBCPP_DEPRECATED ^ E:\Program Files\Arm\Development Studio 2019.1\sw\ARMCompiler6.13\bin\..\include\libcxx\__config:962:48: note: expanded from macro '_LIBCPP_DEPRECATED' # define _LIBCPP_DEPRECATED __attribute__ ((deprecated)) ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:43: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/autotuned_index.h:36: C:\openCV\build_opencv\install\include\opencv2/flann/index_testing.h:95:9: error: cannot use 'throw' with exceptions disabled throw FLANNException("Ground truth is not computed for as many neighbors as requested"); ^ In file included from ../depth/depth.cpp:12: In file included from C:\openCV\build_opencv\install\include\opencv2/opencv.hpp:62: In file included from C:\openCV\build_opencv\install\include\opencv2/flann.hpp:48: In file included from C:\openCV\build_opencv\install\include\opencv2/flann/flann_base.hpp:43: C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:83:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Unknown index type"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:112:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Unknown index type"); ^ C:\openCV\build_opencv\install\include\opencv2/flann/all_indices.h:138:13: error: cannot use 'throw' with exceptions disabled throw FLANNException("Unknown index type"); ^ fatal error: too many errors emitted, stopping now [-ferror-limit=] 2 warnings and 20 errors generated. make: *** [depth/subdir.mk:20: depth/depth.o] Error 1 17:22:11 Build Finished (took 4s.192ms)
It looks like you have exception support disabled using the -fno-exceptions, but you're compiling code that throws exceptions. You can find the latest AC6 reference guide here: https://developer.arm.com/tools-and-software/embedded/arm-compiler/documentation/version-6-13 the option is described in section B1.21
Paul.
Thanks paul,
I guess that I'll switch to linaro gcc since I'm trageting armv7.
