Default crt0.o startup for GCC - Cortex M0
I am trying to write a bootloader that fits within a 4Kbyte space and I'm trying to keep the essential code as small as possible.
However, with the standard default setup from the CMSDK Cortex M0 enviroment, even with a empty main(), I notice that it has already taken up almost 2.5Kbytes
Looking further into the compiled code, I noticed that crt0.o uses some functions which are taking up space some of them below ( dumped from *nm)
20000430 00000004 D _impure_ptr
3000022a 00000004 T main
30000438 00000010 T atexit
30000324 00000018 t register_fini
30000230 00000020 T exit
30000448 00000034 T __libc_fini_array
30000198 00000044 T Reset_Handler
30000250 00000048 T __libc_init_array
30000298 0000008c T memset
30000000 000000c0 T __isr_vector
3000047c 000000d4 T __register_exitproc
3000033c 000000fc T __call_exitprocs
What does crt0.o do anyways and I thought all the necessary copy-downs from Flash to RAM are already defined in startup_CMSDK_CM0.s.
Can I exclude calling this file and go straight to startup_CMSDK_CM0.s?
Also looking at the linker script sections.ld there are references to crt and ctors. Can I exclude those as well?
                /* .ctors */
                *crtbegin.o(.ctors)
                *crtbegin?.o(.ctors)
                *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
                *(SORT(.ctors.*))
                *(.ctors)
                /* .dtors */
                *crtbegin.o(.dtors)
                *crtbegin?.o(.dtors)
                *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
                *(SORT(.dtors.*))
                *(.dtors)
                *(.rodata*)
Just starting out with programming on Cortex M0 so any help is appreciated, cheers.
  • You want to use the libc_nano.a and not the libc.a.  This will reduce your code size significantly.
  • Thanks for the reply, however I notice those functions are contained in libnosys.a.
    The linker file includes these 4 libraries
    GROUP(libgcc.a libc.a libm.a libnosys.a)
    And for an empty main() only libnosys.a is required (found this out through trial and error). But I will try your suggestion anyways.
  • Found more proper solution by looking at the example code in the GCC install rather than from CMSDK. I used the setup and switches from samples/src/minimum and it compiles to a very small code now.
    I noticed that could have been a typo in the CMSDK ARM package for the startup_CMSDK_CM0.s. With a '*.s' this causes GCC not to preprocess the file and thus causing all the defines (for eg stack pointer etc) not to be evaluated. This was also the reason I count not redefine __START to another value.
    I renamed it to  startup_CMSDK_CM0.S which indicates that it needs to be preprocessed and all the defines work now.
