I downloaded a pwm library and ı would like to add those to my keil project window. I created a new file group from Project workspace of KEIL. And ı added all .c and .h files. When ı include those libraries ı got "fatal error: ..... file not found" error. So What ı am doing wrong?
Why have you not posted this in the Keil forum?
sharp said:a pwm library
By "library" here, you mean just a set of source files - rather than an actual, pre-built binary library file?
Such source files are no different to any other source files.
Are you sure this library is intended for use with Keil?
It would help to give a link so that we know what you're talking about.
sharp said: ı added all .c and .h files
Note that there's no need to add .h files to the project - the compiler will find those for itself via the Include Paths setting.
It doesn't hurt to add them, but it also does not help the compiler to find them - you still need to correctly configure the Include Paths.
sharp said:ı got "fatal error: ..... file not found" error
Where, exactly, did you get that?
Also, Please copy & paste the complete message
sharp said:What ı am doing wrong?
Not setting up the Include Paths?
Have you worked through Keil's learning page:
http://www2.keil.com/mdk5/learn
